which intake bolts should i use?
Old Jun 10, 2004 | 11:13 AM
IROCZ88x's Avatar
Car: 1988 IROC-Z
Engine: LB9
hey, swappin my tpi intake...which bolts should i use/what size are they? I guess id like to use some nice ARP bolts...which ones are for tpi...or are they the same for whatever intake?
ok thanks a lot guys
Old Jun 10, 2004 | 11:22 AM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
the stock torx bolts should be fine but if you dont have those any intake bolt should work fine, stock or aftermarket. when you put them in be sure to put sealer on them like you do on cylinder heads. the reason for this is to keep the intake bolts from loosening. when the bolts get loose oil travels up the threads and oil will pool on the outside of the intake base. this will also cause the intake manifold gaskets to detiorate and you could develop a coolant leak in time. i know because the oil puddle is a common TPI thing, and when i rebuilt my 305 all that i listed above had happened to my engine.
Old Jun 10, 2004 | 11:38 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
I got that pretty stainless top end kit from TPiS . My motor guy doesn't like the stainless hardware ..... just called it annoying
Old Jun 10, 2004 | 11:50 AM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
I found some corvette guy on ebay that was selling hex head kits for the TPI. Another easy way to this is take the bolts for you intake to ACE/Home Depot etc and match hex headbolts to what you have, just don't get them mixed up if you don't know which ones came from where.
Terrell351
Jun 13, 2021 01:13 PM
deracer
Apr 11, 2016 12:04 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
theurge
Aug 21, 2015 12:46 PM
