HELP, gas running out of the throttlebody.
Old Jun 13, 2004 | 06:45 PM
Brad91Rs's Avatar
Car: 1991 RS and 1998 Trans Am
Engine: 6.0L(lq4) & 5.7L(ls1)
Transmission: 4L60e
Axle/Gears: 323
I just put the L98 in a 1991 corvette back together after putting new rings and gaskets in it. Now I just tried to fire it up and it backfired and a lot of gas began running out of the throttlebody. What could be causing this? If anybody can give me some quick help I would appreciate it.
Old Jun 13, 2004 | 07:11 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
fireing order is wrong ?
Old Jun 13, 2004 | 07:15 PM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Re: HELP, gas running out of the throttlebody.
Someone else had this problem a little while ago and I believe it was the fuel pressure regulator.
Old Jun 18, 2004 | 03:19 PM
Brad91Rs's Avatar
Transmission: 4L60e
Axle/Gears: 323
Well the firing order is fine, how do I check to see if the fuel pressure regulator is bad? Also if it is bad, I have a spare TPI from a 305, could I use the Fuel pressure regulator off of it? Thanks.
Old Jun 18, 2004 | 06:31 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
Pull the vacuum hose off the pressure regulator, gas will come out of the nipple if the diaphram is torn.
The regulator off your 305 should be the same.
Old Jun 20, 2004 | 01:38 PM
Brad91Rs's Avatar
Transmission: 4L60e
Axle/Gears: 323
Well, it turns out the fuel pressure regulator was shot after all. It also turns out that I'm gonna need new injectors because they were clogged too. Hopefully when I get the injectors put in it will fire right up.
Old Jun 20, 2004 | 05:02 PM
Good job finding the problem...
92camaroJoe
Jul 29, 2023 07:57 PM
BurlyChev
Aug 16, 2015 09:08 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Bradsaundry
Aug 12, 2015 12:34 AM
