got a stealthram and 383....new to heads opinions...facts
Old Jun 15, 2004 | 12:39 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
ok i will be running a 383 with the stealthram. more than likely a 58mm tb and 36# injectors. the cam will come last but wont be puny by ANY means......gotta love a rough idle. but im pretty new to this stuff and just need help in three areas (well probably all areas)
first: what size should i get 200cc 220cc more?????
second: intake and exhaust valves....what would be some good sizes to run with this combo?
third: brands!!! there are so many and i hear different stories for each one by different people. i need some that will be great out of the box (fully assembled) but are relativly priced. i want to stay under a grand, used is fine with me.
keep in mind the cam will match my heads after i get the heads, i want to keep as much low end torque as possible since the tracj time will come only every month or so.
searches just keep confusing me!!!
Old Jun 15, 2004 | 10:04 AM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Under a grand limits the choices considerably.
Old Jun 15, 2004 | 11:18 AM
Insomniac92z28's Avatar
Car: 92Z28
Transmission: A4
Bang for the buck the pro toplines with some bowl work flow great. I have seen 180cc runnered cast iron heads flow over 280cfm @.600 lift and flow awesome down low too. You can get them cheap on Ebay and have someone blend the bowls and backcut the valves and you will have as much airflow as AFRs for much less $$$.
No offense to you AFR owners, they are great heads.
JMO,
Charlie
Old Jun 16, 2004 | 12:51 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
anyone else i need a little help here. im thinking 220cc runners 2.02/1.6 valves and pretty much any brand i can find for under a grand. some pocket porting will probably be done since il have the heads for a while before the engine is assembled. also, angled or straight plugs???
Old Jun 25, 2004 | 10:20 PM
1987-396-IROC's Avatar
Car: 1987 IROC-Z
Engine: 4 bolt 383
AFR 195cc Heads and get the CNC Competition Porting Package and it will be enough to feed a 500+ horespower engine so i heard.......
Old Jun 25, 2004 | 11:30 PM
305RSlc's Avatar
Car: 1991 Z28 Camaro
Transmission: 700R4 that will magically turn into a 6 speed one day.
Head over and check out the Pro Lightning series from Pro Topline. You can get a complete set of heads assembled for roller, hydraulic, or whatever you want, for under 1K. Now mind you, these are the Iron Lightnings, but they are VERY VERY VERY impressive with their out of the box flow numbers and could easily support a 500hp with no porting. Not to mention the SR will bolt up to them no problem, they can use center bolt valve covers and look completely stock. Just another option.
Old Jun 26, 2004 | 10:54 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
yea ive heard a lot about pro topline. they sound ike the best choice as of now well see when i can actually save the money
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
92projectcamaro
Jan 18, 2016 08:00 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
z28guy134
Sep 1, 2015 11:50 PM
