Where to find runner-to-plenum and IAC housing screws?
Old Jul 1, 2004 | 05:47 PM
ntesla's Avatar
Car: 1989 Formula
Is there anyplace to find these screws except the dealer? I've checked two hardware stores and neither one carries any Torx stuff. Or do I just have to bend over and take it from GM?
Old Jul 1, 2004 | 07:41 PM
Desert86Roc's Avatar
Dont use torx...Ugly and hard to work with. Go with some Stainless Steel socket cap or button heads.. much nicer looking. You might even find a set of them on Ebay. (See pic below)
Old Jul 1, 2004 | 10:09 PM
camaro87's Avatar
Car: 1987 IROC-Z/28
Engine: 305 cid V8
PCV hose
Desert86Iroc,
That's some nice hose you have for the PCV passenger side hose. (I hope I am seeing things correctly and that is hose, not the stock hard line GM uses). I am almost done with a complete redo of my intake and in the process I wanted to get rid of that solid line GM uses for the PCV on the passenger side. I talked to a guy at advanced auto and he said I could do it, only problem might be the heat. Any problems with heat with yours so far? That is a rubber hose, right?
Thanks!
Old Jul 1, 2004 | 11:50 PM
ntesla's Avatar
Car: 1989 Formula
Desert86Roc,
Socket caps are allen drive, right?
1992 Trans Am
May 10, 2023 07:19 PM
Jeremys87
Jul 14, 2022 09:08 PM
specialized
Jun 18, 2022 09:26 AM
aaron7
Aug 26, 2015 09:45 AM
blacksunshine'91
Interior Parts Wanted
Aug 10, 2015 12:04 AM
