CSI Question
Old Jul 2, 2004 | 09:24 AM
Charlz B.'s Avatar
Car: 87 IROC-Z
Engine: LB9
CSI Question
I'm new to Camaros, so everyone's patience is appreciated.
I think the CSI on my car isn't working, since I have to crack the throttle to get the engine started almost all the time. Not surprising; half the things on this car didn't work at the start. Anyway, I only know where the injector is...I have no idea how to test it, or clean it, etc. I might be able to get it out of the engine, but I don't know, I've never tried.
What's the protocol for determining my problem, so I have a course of action? The CTS is fairly new, and supposedly so is the Engine Temp Sensor, but I can't prove that right now.
Who has my answer? Thanks! :rockon:
Old Jul 2, 2004 | 05:51 PM
Roostmeyer's Avatar
Car: 88 Trans Am GTA
Engine: 5.1L Gen III
Axle/Gears: 3.70
Sorry to tell you this, but your barking up the wrong tree. CSI only works at cold temps, hence the name. It does nothing at the 60 and 70+ temps we're haveing right now. You could also change to an ARAP or the corresponding 1989 tpi car chip and disconnect your CSI. Does the car die sometimes, especially when cold? Your Idle set screw may be backed off too far. Set it according to tech articles in on this website. Also set your TPS to 56 mV's, and check to see if the car's throwing any codes. It's always a good idea on a new (used) car to do a full tune up, new wires, plugs, cap and rotor, etc.
I'd also beg, borrow, or steal a scanner. One scan and you'll know if any sensors are bad.
Old Jul 15, 2004 | 08:58 PM
wulff's Avatar
Car: 1987 Monte Carlo SS
Engine: 406 TPI
Transmission: T56 6-speed
Check the IAC motor (it uses a cone-shaped valve to control the amount of air that is needed for idling), it is located under the throttle-body and it might be sticking in the closed position.. it might be worth it to replace it anyhow since you said the car is a little ruff... if you need help adjusting it (it's easy) let us know.
Old Jul 16, 2004 | 06:58 AM
Charlz B.'s Avatar
Car: 87 IROC-Z
Engine: LB9
I just had the IAC motor out about a month ago and gave it a good bath. I reset min air too, and that made me a bit happier with it's idle. Still, the car just doesn't like to start. I can turn the key on, wait 2 secs til I hear a click, crack the gas, and the car'll start pretty easily.
Old Jul 16, 2004 | 09:58 AM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
bad fuel pump relay?
Old Jul 16, 2004 | 11:48 AM
Charlz B.'s Avatar
Car: 87 IROC-Z
Engine: LB9
Yeah, I got the relay answer once before, so there's all new relays up in that part of the engine compartment. Thanks for the idea though....keep 'em coming.
Old Jul 16, 2004 | 12:38 PM
Car: 1988 IROC-Z
take a look at your tps. there is an article teling on setting up and testing your tps sensor. have you reset the min idle/air?
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
