adjustable fuel pressure regulator
Old Jul 15, 2004 | 11:08 PM
FiveSeven's Avatar
Car: 1988 Iroc Z
The guy I purchased the car from says it has a TPIS adjustable fuel pressure regulator. I just need to know where its at...I think I found it. I'm pretty sure its right in front of the distributor,behind/under the intake? If it is, do I have to take the intake off to get at it? Thanks for the help, sorry if its in the wrong forum.
Old Jul 16, 2004 | 12:26 AM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
That is it. You shouldn't have to remove anything to be able to adjust it. It is a little difficult to get to but it can be done.
Old Jul 16, 2004 | 01:16 AM
FiveSeven's Avatar
Car: 1988 Iroc Z
Thanks for the help, I didn't even wanna try to mess with it without being sure. Stock pressure is like 42psi, right? I'm sure since the guy bought it that its probably a little higher now. I should run less than 50 for daily use though, correct? I'll go check it out first thing in the morning...2 A.M. right now lol.
Old Jul 16, 2004 | 01:43 AM
bigals87z28's Avatar
Car: Check The Sig
I suggest you get a fuel pressure gauge that mounts right to the fuel rail to see your pressure. 42-45psi is about stock. Keep it stock for daily driving, up it for track/performance.
You shouldnt have to remove the plenum. There should be a thin, black screw that comes out of the center.
Old Jul 16, 2004 | 06:38 AM
PF Flyer's Avatar
Car: 87 T/A
Engine: TPI 350 ci
Transmission: 5 speed
you definately need the gauge that mounts to the fuel rail to be sure. I have the one offered by TPIS and only put it on to check the pressure when I'm tuning in preparation for a track day.
Old Jul 16, 2004 | 10:22 AM
FiveSeven's Avatar
Car: 1988 Iroc Z
Thanks for the help guys. About how much will I have to spend on a fuel gauge? It will be a while before I get one anyways. Making $5.50/hour and still owe my dad $2500 for lending me the money to buy the car...the only money I keep from paychecks go toward gas.
Old Jul 16, 2004 | 03:07 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
You can get a gauge for under $20.
MustangBeater20
Oct 29, 2022 09:20 PM
9192camaro
16
Feb 3, 2019 12:21 AM
wayshegoes
Aug 17, 2015 12:00 PM
89-S-dime
Aug 12, 2015 11:57 AM
Kaweh
Aug 9, 2015 02:54 PM
