torque converter
Old Jul 8, 2004 | 11:42 AM
thirdgenner05's Avatar
Car: 89 t/a
torque converter
alright alot of people recommend vigilante converters Im just wondering what the big difference between those or a tci or some other brand is I mean, their all made to perform the same function so why does one cost upwards of 300 dollars more than the other. Sorry if this is a stupid question I just dont feel like throwing my money away.
Jason
Old Jul 8, 2004 | 12:48 PM
formularpm's Avatar
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
Those arent the only two choices. Also look into Edge, Midwest, or ACT. They are all 9.5in lockups and priced around $600.
Old Jul 8, 2004 | 05:16 PM
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
you also need to know what STR you want. This is what effects how hard you hit the tires off the line and the effieciency up top.
Mods: please move this to the tranny board.
Old Jul 8, 2004 | 10:49 PM
Car: 89 t/a
what is str? sorry Im new to the world of cars being 16 and all. also will these do as good as a vigilante or as a tci or edge?
http://cgi.ebay.com/ebaymotors/ws/eB...sPageName=WDVW
or
thanks very much
Jason
Old Jul 9, 2004 | 11:35 AM
Engine: LB9/383
Stall Torque ratio. Kinda complicated to explain. My last converter was around a 1.8 in my L03 and it hit the tires quite a bit harder than stock, but sacrificed some efficiency up top but not too bad.
Old Jul 9, 2004 | 01:28 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
If all you are running is the stock motor and a few mods, then the tci and b&m convertors are ok. I've seen 1 b&m 2400 break behind a 350 miniram, iroc, et streets, and have heard of a few more on here, do a search and make your own decision based on the results.
Old Jul 9, 2004 | 02:04 PM
Engine: LB9/383
And their lockup clutches burn up quick too, they run super-hot and the torrington bearings come apart inside. TCI's are ok in these cars, but I've seen way too many problematic B&M's. Bottom line is that you need to match the converter to the car's setup or else you'll never get the maximum out of your mods.
Old Jul 10, 2004 | 12:02 AM
Car: 89 t/a
alright Im probably gonna end up going with the vigilante due to the fact I know it would sustain most of anything Ill ever do to the car thanks yall
Jason
Old Jul 10, 2004 | 12:30 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Originally posted by NastyL98_T/A
...Mods: please move this to the tranny board.
No, please, tell them how to do their job. Publicly. Without the use of PMs.
PMs - they are your friend.
seiplentz
Aug 19, 2019 06:02 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ragtop Man
Sep 12, 2015 12:23 AM
Nick McCardle
Sep 10, 2015 08:36 PM
