LT-1 Intane AND Heads on an L98?
Old Jul 8, 2004 | 04:34 PM
CarAteMyMoney's Avatar
I'm about to put my new engine together...
...a friend of mine suggested that if i'm going to use an LT-1 Intake conversion on my L98 setup, I should use the heads as well because they flow better than previous designs, and there will be no mating issues between the intake and heads.
He also said that the lt-1 heads have ports in the back so that coolant can exit there and then be routed to a remote thermostat housing and on to the radiator.
Are there any other issues that should be addressed before I investigate this any further?
Old Jul 8, 2004 | 04:43 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
LT-1 (asuming the 93-up LT1) heads are reverse cooling and require some modifcations to coolant passages. For most, it's not worth the effort.
Old Jul 9, 2004 | 07:27 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
tpi_roc is doing the LT1 intake and heads conversion. Here's a link to how he converted the LT1 heads.
https://www.thirdgen.org/techbb2/sho...hreadid=178262
His conversion is based on the magazine article here.
http://www.lt1intake.com/LT1_retrofit.htm
As far as it being a waste of time, it may be for some people. Think about the combo you'll have for next to nothing. LT1 heads are going for $250 on ebay right now. Even adding $100 to rebuild them and you're still starting cheap. Used complete LT1 intakes are around $120. Cheap is the reason. Fast is the result.
Old Jul 9, 2004 | 08:26 AM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
A good set of SBC Gen I heads would be cheaper and would be less work with the same output. I would say that it isn't worth the time or money, but sometimes that just makes some people want to do it all the more.
Old Jul 9, 2004 | 03:35 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
LT1 heads are also aluminum though, no?
Old Jul 9, 2004 | 04:15 PM
Engine: 4.0L
Where can I find a good set of aluminum SBC Gen I heads for $250? LT1 heads flow better then any previous GM design anyway.
Also, if you are going to do a LT1 intake conversion it seems only logical to use LT1 heads too if you can. Makes it very easy to convert a LT1 intake when all you need to wory about is the distributor.
Old Jul 9, 2004 | 04:17 PM
Engine: 4.0L
They are unless you got them from a Caprice, Roadmaster, Fleetwood, etc......all those big cars used iron LT1's.
I believe only the F-bodies and Y-bodies got the aluminum LT1 heads.
Old Jul 9, 2004 | 05:13 PM
Car: 1997 Corvette
Oh, okay, because I know my buddy has aluminum ones on his '97 Z, but that makes sense if it was only the F and Y-bodies
Old Jul 9, 2004 | 05:27 PM
350 TPI's Avatar
I came across an LT1 out of a 94 roadmaster today.It was very clean.Do these motors also have reverse cooling??I know they are down a little in power(260 vs275) but the price should be a little cheaper( hopefully).
Old Jul 9, 2004 | 05:48 PM
I have a set of 624's that flow 225cfm for $300 so iron heads that flow well are available for cheap
I was thinking of doing the lt-1 heads because i could get away with a bit higher compression and nicer chambers
but i'll probably end up sticking with the 882's im having done
Old Jul 9, 2004 | 05:55 PM
Engine: 4.0L
As long as it's a 5.7L LT1 it is reverse cooled, it only has iron heads instead of aluminum and a smaller cam.
Be aware there are 4.3L L99's (still a V-8) that look exactly like LT1's.
Old Jul 9, 2004 | 07:11 PM
350 TPI's Avatar
John,was the 4.3 available in the roadmaster in 94??It has that written across it.Where will 5.7 or 4.3 be stamped on the block??Its in a building with a hundred other motors.
Old Jul 9, 2004 | 08:23 PM
Engine: 4.0L
I don't think the 4.3L V-8 was available in Roadmasters, only Caprices. Never know though unless you know the engine is orginal.
What does the engine have written across it? 4.3L? You didn't say.
Old Jul 9, 2004 | 08:27 PM
350 TPI's Avatar
I am not sure it had what size the motor was but it had the big piece of plastic on top that covers the engine and it said buick or roadmaster or something like that.Wish i would have paid more attention.
Old Jul 11, 2004 | 09:42 AM
rightfoot's Avatar
Car: it is broken
Engine: 327 in 89 block tpi
Transmission: 200r4
5.7 or 4.3
all the 4.3 engines have 4.3 cast into the bellhousing flange where the casting numbers used to be.
Old Jul 11, 2004 | 11:04 PM
92rs85berlintta's Avatar
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
im not a head expert or anything but ive heard alot of horror storys i believe about the 882 heads. maybee a set of 416 or 601 heads would be better if you could dig them up. just a suggestion.
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
how much hp did these mighty 4.3 v8s put out anyway?
Old Jul 11, 2004 | 11:30 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
he is correct. The 882's are smogger crap pieces. Their 76cc chambers EASILY offset the performance from work done to them. Get a set of 416's, 601's, or other comprable head and have at them. They can be found easily at the junk yard. Avoid TBI heads.
Old Jul 13, 2004 | 01:38 PM
tpi_roc's Avatar
Lighter
Higher compression
Better flow
Perdy
Cheap
Seemless LT1 intake install
Can't lose :lala:
lt500r55
Sep 1, 2021 01:30 PM
CRFred
Feb 7, 2016 11:39 PM
italiano67
Aug 31, 2015 06:04 PM
anesthes
Aug 8, 2015 09:37 PM
cRoe4
Aug 7, 2015 08:46 PM
