Fuel Pressure Regulator Questions
Old Jul 10, 2004 | 10:21 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
I am currently using Accel 24# injectors in my TPI motor.
However, I am using the stock fuel pressure regulator.
I have seen ads for various aftermarket AFPR's.
I'm not clear on how adjusting the fuel pressure directly affects the amount of fuel sprayed by an injector.
Isn't an injector designed to only move so much fuel (volume) at a fixed rate?
Also, since I am running the 24# injectors with the stock FPR,
should I be using an aftermarket chip? Currently, the car runs fine with the stock one, but I didn't know if I was "missing-out" on any performance gains by not using one with my 24# injectors?
Any information would be appreciated.
Thank you for your time.
Old Jul 10, 2004 | 10:43 PM
Mesix's Avatar
Car: '87 Trans Am
Engine: L98 (Corvette)
Transmission: M5
From what I gathered, the increased pressure still sends the same amount of fuel through the injectors, but it has improved atomizaation, thus more effiecient burning. I could be wrong though.
Old Jul 11, 2004 | 11:57 PM
jerflash's Avatar
Car: 90 Formula, 02 ws6
Engine: 305 tpi, ls1
Transmission: 700r4, t-56
Axle/Gears: stock posi 2.73, 12 bolt with 4.11s
the more pressure that is present the more the injector will flow
are fuel injectore on are cars are rater using 42lbs of pressure but ford rates theres at around 36 lbs
MustangBeater20
Oct 29, 2022 09:20 PM
9192camaro
16
Feb 3, 2019 12:21 AM
wayshegoes
Aug 17, 2015 12:00 PM
89-S-dime
Aug 12, 2015 11:57 AM
Kaweh
Aug 9, 2015 02:54 PM
