Did the search but...(110 LSA Cam for 383)
Old Jul 19, 2004 | 01:08 PM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
How streetable can you make a 110 LSA cam? I have heard a bunch of mixed results. There are people running the 110 with no troubles and very streetable, but then there are others that are running 112 and having problems with vaccum.
The reason I ask is because I am going to be running a non-roller block for my 383, due to lack of funds, and with the help of a friend a while ago I picked out a 110 LSA cam because he was going to help me with prom tuning. Will I be running into major issues? Not to sound like a richard but, please come with real world examples also because I base my decisions on facts and only facts not on, my brothers, uncles, cousins, sisters, boyfriends 92 Z runs this. Thanks.
Old Jul 19, 2004 | 01:09 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
What are the rest of the cam specs?
Assuming it's nothing crazy, they are usually streetable. Moreso in a carb setup than in an EFI. If you can burn PROM's they can be run, again, assuming nothing crazy.
Old Jul 19, 2004 | 01:22 PM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
The cam is
228 intake/234 exhaust .480 in./.494 in. 110
It is Trickflows cam.
Old Jul 19, 2004 | 03:01 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
What ecm? You should be able to tune that cam, don't let everyone scare you off. In a week or so, I will be tuning and passing emissions with a bigger cam than that on a 110lsa. If you have problems with vacuum, then turn up the idle or get a vacuum canister.
Old Jul 19, 2004 | 03:31 PM
Eats5.0's's Avatar
Car: 84 Berlinetta
Engine: junk 350
Transmission: TH350
Axle/Gears: Moser 4.56
89GTA,, I'm hoping to get mine running first.. I have a 110LSA also, and am close to firing up the motor for the first time. I just want it to run first,, then I can worry about burning a chip for it. Vacuum canister,, well I may just have to add that to the cost of everything else.. I think my cam specs are .502, .510 int/exh, but I have 1.6 rr's too.
All I can do is have no brakes,, lol
Old Jul 19, 2004 | 05:10 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Dunno if this will help you or not, but here are my cam specs , I'm running a 110 LSA on a roller setup. After some tuning, no problems at all..
Old Jul 20, 2004 | 08:57 AM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
I will be running the MAF system. I do not trust myself to repin it just yet, I will have to do more research before I do that.
So no one has vaccum problems as of yet? After doing some more searching and reading what you guys have to say, I am ready to get this thing put together and start it up.
Juneb1022
Firebirds Wanted
Oct 12, 2015 08:12 PM
beastin91rs
Oct 9, 2015 07:38 AM
gixxer92
Sep 1, 2015 04:32 PM
mz92274
Aug 25, 2015 08:47 AM
80s Poncho
Aug 19, 2015 06:45 PM
