Cold start enrichment?
Old Jul 20, 2004 | 11:53 AM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
My 88 L98 is pretty hard to start first thing in the morning. Has start signal to the crank fuse. Looking through wiring diagrams I can't really find any wire from this to the ECM. I know the early cars used this to trigger the cold start injector but do the newer engines actually have a startup enrichment of some sort? Also, mine takes at least 10 to 12 revs before it fires, maybe this is normal?
Old Jul 20, 2004 | 11:59 AM
wwnf's Avatar
Car: 86 IROC
Engine: SC'ed 350
Axle/Gears: 4.11 12bolt
From what I've read on this site the CSI is independent of the ECM and works off a sensor. Newer cars, 89 and up I believe don't have the CSI but added crank routines in the ECM. I switched my 86 $32 code to 89 $6E code (no CSI) and my car starts much better without the CSI. I have a new starter too so that helps a little. It takes my car 2-3 cranks or less now, fires right up.
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
