HSR and distributor cap
Old Jul 20, 2004 | 11:41 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Transmission: Slipping
Is it just me, or is it a pain in the rear to swap the distributor cap with a Stealth Ram? I managed to get it out by unplugging my wiper motor. It hits the vacuum ports on the back if I do it any other way.
Anyone else have a special trick to taking the cap off or having better vacuum fittings that are more compatible?
Old Jul 21, 2004 | 07:00 AM
CashMunson's Avatar
Car: 87 Trans Am GTA
Engine: 408 LS
Transmission: LS 4L60E
Axle/Gears: 9 Bolt/3.70 Gears/TAP Girdle
You could go with 90 degree fittings on the back and that would probably give a little extra room. I have the same problem with my GTA, you can just barely get the cap out if you turn it sideways and take it out on the driveside between the plenum and the whiper motor. It's just one of those things we'll have to deal with I guess because there really is no way to get around it that I can see.
Old Jul 21, 2004 | 11:55 PM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Re: HSR and distributor cap
I am assuming you have a small cap dist? I do and I havent tried to change it cuz its still new. I will go out and look later to see if I think it will be a problem but I dont think so. If I remember right, I had to drop the dist in without the cap on and then add the cap and it wasnt a problem for me. But I am old and my memory is fading.... My guess is that this is probably a formula/gta/tta/firebird issue?
Old Jul 22, 2004 | 01:11 AM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Well, this is on a Camaro.
I put the dist in with the plenum off. And yes, small cap dist.
MM2Robinson
Oct 1, 2017 09:16 AM
86CamaroDan
Sep 29, 2015 10:08 PM
camarohelp
Sep 22, 2015 03:19 PM
m00n420
Sep 11, 2015 02:39 PM
Jlanz55
Sep 6, 2015 03:05 PM
