LT1 cam??
Old Jul 21, 2004 | 09:30 AM
3rdGenSS's Avatar
Car: 91Z28, 94 Silverado, 99Z28
Engine: 350 TPI, 350 TBI, LS1
Transmission: 700R4, 4L60E, 6-speed
Axle/Gears: 3.42, 3.42, 3.42
LT1 cam??
i know it may be covered but i have not found anthing on using an LT1 cam in a L98 motor.... everything seems to be 305.. anyways... would the LT1 cam be a better option then the l98 cam... im getting an engine this weekend from an 87 iroc... and while freshening it up i am thinking of changing the cam. as i can get the lt1 cam for cheap i would put it in if it would be an improvment over the l98 cam... if it is better... is it a direct swap (other then the pin needing pushed in or cut off).. or is there other parts or things that need to be done.. thanks for any help
Old Jul 21, 2004 | 12:57 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
I asked the same question the other day, and the answer I got was that there isn't enough difference to warrant the swap. I dunno though, it's just what I was told.
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
88 TA GTA
LSX and LTX Parts
Sep 11, 2015 11:31 PM
L0tuS
Sep 4, 2015 11:16 PM
Strick1
Sep 4, 2015 07:11 AM
