plenum questions
Old Jul 24, 2004 | 03:12 PM
no1kicker's Avatar
Car: 1991 Trans Am
Engine: 5.3L
Transmission: auto
plenum questions
First off I have a 1991 305 tpi. I want to port my plenum, or get a ported one, and I have some questions.
If I stick with stock runners, is it worth it to port the runner openings on the plenum?
I see some people have ported to accept slp runners, by taking out the material in the middles of the runner openings. If I do this, and use the stock runners, will there be any negative effects?
If I can get one that's ported for a 58mm TB, and use the stock 52mm, will there be any negative effects?
Thanks.
Old Jul 24, 2004 | 04:50 PM
robsgta's Avatar
Car: 88GTAnotchbac/91 -Z/66 Chevelle
Engine: All strokers
Transmission: Pro built 700r4's
plenums
The more material that you get out of the way the better off you are also making the outer edges smooth on the inside is just as important.
The only problem you dont want to have is grinding out side the gasket area to a point to where you cant get your intake or runners to seal.. More air flowing happily through your intake will have a positive effect.
MantyZ28
16
Dec 21, 2015 11:02 AM
Thaney9
Aug 29, 2015 03:16 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
355tpipickup
Aug 22, 2015 06:06 PM
redmaroz
Aug 16, 2015 11:40 PM
