Fan Switch
Old Jul 27, 2004 | 08:55 AM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Fan Switch
Can anyone tell me where my fan switch is located (for my auxillary) fan on my L98? If someone had a pic or diagram that they could share or refer me to, I would appreciate it. Also (not to ask a completely stupid question) but if I unscrew this from the block, is coolant going to leak out?
Thank you for your time.
Old Jul 27, 2004 | 12:39 PM
jwscab's Avatar
Engine: Many
Transmission: Quite a few
the aux or secondary cooling fan thermostatic switch is located in the cylinder head on the passenger side, in between cylinders 6 and 8. Yes, coolant will leak out unless you drain it first. HTH
Bubbajones_ya
Jul 6, 2024 08:32 PM
gta892000
Aug 11, 2019 11:16 AM
FormulasOnly
Sep 10, 2015 09:07 PM
64goatman
Sep 9, 2015 01:09 PM
85Special
Sep 3, 2015 04:21 PM
