What can cause a backfire?
Old Jul 28, 2004 | 12:51 PM
5SIZ's Avatar
Car: 1987 IROC-Z
For some strange reason my car is backfiring every time I push in my clutch to shift? What could be causing it? Timing?
Any help will be greatly appreciated.
Old Jul 28, 2004 | 01:23 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
air leaks.
my car was doing the same thing this weekend... athough i already knew what it was..
if you have a leak in the exhaust system, fresh air gets pulled in. that mixes with the fuel, so when you clutch, it ignites and backfires.
its the most common cause of backfires..
if you have headers, id start by checking your header and collector gaskets.. in my case, it was my collector gasket... i replaced it with a embossed copper gasket.. it'll never blow out again.
Old Jul 28, 2004 | 06:44 PM
White91GTA's Avatar
Car: 1991 Trans AM GTA
Engine: 5.7L TPI
Originally posted by MrDude_1
air leaks.
good advice...mine backfires when i let out of the throttle really quick to start slowing down to exit the highway. i will have to check those areas for leaks
Old Jul 29, 2004 | 12:18 AM
5SIZ's Avatar
Car: 1987 IROC-Z
yeap, if I push in the clutch quickly it will backfire, I checked my headers for exaust leaks and a couple of bolts were loose but nothing major & still I backfire just not as bad, I will have to check my collectors.
thanks.
Old Jul 29, 2004 | 08:52 AM
redlightrunner's Avatar
if its carbd. u could have a problem there beacuse on a carb car u can put ur hand over the carb wait till its about to die and then it will back fire because u gave it a rush of air
Old Jul 29, 2004 | 09:10 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
actually, the reason some cars do that is two fold.
1. when you put your hand over the carb, it starts running richer. this extra unburnt fuel starts to build up in the exhaust...
2. theres air getting in there... either from having the carb running lean, or from header/collector/pinhole air leaks...
the O2 mixes with the fuel and you get a backfire out the exhaust.
tyeo098
Nov 30, 2015 06:27 PM
racereese
Oct 3, 2015 03:46 PM
85 Jimmy
Sep 30, 2015 07:56 AM
RedLeader289
Sep 23, 2015 06:50 AM
Racerx974
Sep 19, 2015 10:16 AM
