comp cams 292 cam
Old Jul 29, 2004 | 10:36 PM
86IROCTHD's Avatar
Car: 88 Trans Am
Engine: lt1 intaked 355 makin 277 on 25 psi of fuel pressure and stock timing :)
Transmission: A4 stock... that moved a mobile dyno a foot shifting into 2nd :)
comp cams 292 cam
hey guys i am building a 355 with an lt1 intake and 24 lbs injectors would this cam a comp cam 292 cam work with my motor/intake, i dont know if it will idle at all please help me out... thanks
Old Jul 29, 2004 | 11:48 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Im going to assume thats the 292h Magnum grind? If so, It won't run very well. At least not with extensive PROM burning, and at that, I'm not even sure that will make a difference. That is primarily a carb'd engine cam.
Get an EFI cam. You will be much happier in the long run.
Old Jul 30, 2004 | 01:12 AM
Z69's Avatar
Z69
Waste of time with stock heads too.
and a LR intake....
Old Jul 30, 2004 | 06:00 PM
86IROCTHD's Avatar
Car: 88 Trans Am
well what cam would u guys suggest... and also what heads?
Old Jul 30, 2004 | 07:34 PM
Z69's Avatar
Z69
Actually need to know what you want to do....
Based on the intake and huge cam you started with:
In order of lowest to highest price/flow
Trick Flows are the cheapest decent head,
Then AFR 195's
Then Brodix RR200 w/cnc chamber.
You can order these heads with w/springs to match your cam.
Cams in the range of 270-280 adv dur. and 220-230 @.050.
with 112-114 LSA.
two examples are Comp xx-305-x and xx-503-x part numbers.
The first is the older HR lobe while the 503 is an XE HR with similar dur., less overlap, and more lift. But it also needs stiffer springs to rev. and is a custom order for a 114 lsa. Like $20 more and the cam goes through a diff. QC inspection than the shelf stuff. -better-
You'll need more gear for these too.
and a different chip..
And you might want to just start with 30's to begin with.
See here for a thread w/links to similar motors.
425Hp
Intake?
F.I. 57 Belair
Aug 23, 2021 01:09 AM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
sandman92084
Sep 12, 2015 10:27 PM
Strick1
Sep 4, 2015 07:11 AM
