MAF help
Old Aug 1, 2004 | 08:15 AM
mitchc's Avatar
MAF help
I purchased a MAF sensor the other day that only has 3 wires. Its a Bosch unit with the circut board. I'm assuming that it does not have the burn off function since it does not have the wire sensor. My question is can I wire this unit on my 87 tpi setup and just not use the burn off function?
Thanks Mitch
Old Aug 1, 2004 | 12:59 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
You'd have to provide a part number for certain determination of the function. The L98 uses a voltage differential type MAF whereas other GM products use a frequency type MAF. If it's the voltage type, it might be able to be adapted for use.
Mark_ZZ3
May 24, 2018 01:02 PM
BumpaD82
Feb 26, 2016 02:57 PM
racereese
Oct 3, 2015 03:46 PM
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
