Hard to Start TPI 305
Old Aug 1, 2004 | 10:38 PM
brickwahl681's Avatar
Car: 88 camaro, 86 iroc, 2000 silverado z71
Engine: 355, 305, and 5.3
Transmission: manual, automatic
Please help, I have a 86 iroc 305ci with a 700r4 that just does not want to start. It only has a hard time starting the first time. after that it starts fine. It has already been given a complete tune up including ignition module and tps sensor. I did notice the other day when I got into the gas good I heard a back fire in the intake manifold. I am lost. Has anyone incountered this before. I am starting to think that she might have jumped time. It does have 122,000 miles. I have had it on a snap on scanner and a scope and the MAP, O2, and Air temp sensors all seem to work fine.
Old Aug 1, 2004 | 11:33 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
It sounds like the battery is about gone on it. It doesn't appear to be holding a charge. That would explain why it starts fine all other times because it gets charged up once it's been running then once it sits for a while the battery starts to drain.
Old Aug 3, 2004 | 07:57 PM
what I ment by hard to start is that it cranks and cranks. To get it to start I have to depress the gas pedal as if it was carburated. IT will usually spit and sputter until it gets warmed up, simular to if you had a huge vacume leak or it was out of time but I checked both and it seemes to be ok there.
Old Aug 3, 2004 | 08:18 PM
91CamaroZ's Avatar
It almost sounds like your STARTER is sticking or going bad. I had the same problem with it wanting to start sometimes and not others. Replaced the starter and haven't had any problems since. Just a thought.
Old Aug 4, 2004 | 09:54 AM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
More common than you think maybe:
https://www.thirdgen.org/techbb2/sho...hreadid=252025
Old Aug 4, 2004 | 02:07 PM
it cranks fine. There is nothing wrong with the ignition system, starter, fuel system or the battery.
Fast355
Dec 2, 2016 06:33 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 10, 2015 07:44 AM
drathaar907
Aug 6, 2015 04:20 PM
