horrible sound and loss of torque HELP!
Old Aug 2, 2004 | 11:32 AM
moreyes's Avatar
Car: 85 TA
Engine: 305 tpi
Transmission: 700
Its impossible to have a quick cold start in the morning. i have to pump the gas pedal as i turn the ignition to get it going. Once it goes, i can see a cloud of gray smoke coming out of my exhaust. I give it a little gas to get going and it hesitates a couple of times until it passes 5mph. Once im on the road the engine makes these quick puffing sounds that increase with the rpms. at idle the whole car shakes a bit too much. I have to get oil every 2 weeks and yet no puddles under the car.
Some people say its an intake leak, some people say its a head gasket leak.
I dont know what to do. The smoke has this weird bitter smell.
Old Aug 2, 2004 | 08:53 PM
moreyes's Avatar
Car: 85 TA
Engine: 305 tpi
Transmission: 700
help me guys!
Old Aug 2, 2004 | 10:51 PM
DON 88T/A's Avatar
I assume you have no check engine light?
How much oil you adding every two weeks?
Does your oil have a milky look to it?
Antifreeze have oil in it?
Unless you have a very bad miss(check plugs/wires ect.)....it does not sound good....do a leak down test on the cylinders.
Does it do this after it reaches closed loop?
Old Aug 2, 2004 | 11:01 PM
moreyes's Avatar
Car: 85 TA
Engine: 305 tpi
Transmission: 700
engine light comes on at idle
I end up addint anywhere between 1 and 2 quarts
oil doesnt look milky actually quite dark
no antifreeze mix
it hasnt had a tune up in a long time could that be it?
Old Aug 3, 2004 | 01:34 AM
5SIZ's Avatar
Car: 1987 IROC-Z
if the engine light is coming on @ idle then what code is it throwing?????
do you know how to check the codes?
MM2Robinson
Oct 1, 2017 09:16 AM
92firebirdguy
Sep 1, 2016 07:53 AM
Ragtop Man
Sep 12, 2015 12:23 AM
Blue419
Sep 10, 2015 01:03 PM
SG91camaro
Sep 5, 2015 10:27 PM
