weird bolt preventing remove of runners
Old Aug 2, 2004 | 07:12 PM
trueburton's Avatar
Car: '88 Red Trans Am w/ T-tops
ok so there is a bolt on the front of pass side runner that looks like a regular bolt but at the end it looks like i needle/spindle about a 1/16 of an inch in diameter by 1 inch long. when i try to turn i it it looks like it is twisting the bolt and ready to break so i haven't wrenched on it hard any ideas?
Old Aug 3, 2004 | 11:58 AM
Scott 88 GTA's Avatar
Car: 88 GTA
Engine: modified L98
Axle/Gears: 3.27 9-bolt
Please don't take offense at this, becuase it's not clear in your post..... But, are you trying to twist on the long skinny part? You should just be able to slip a regular old box-end wrench over the spindle down to where the regular style bolt head is. Where are you seeing it twisting?
Also, this is a factory bolt. The only reason for the spindle part to be there is it gives the throttle and cruise cables something to rest on, that's all. I don't think it's a big deal if you break it off or put a regular bolt back in later.
Old Aug 3, 2004 | 05:22 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
If that is the bolt that I am thinking about, it is in the wrong location. It should be as shown in this picture. The hex portion of it is 11MM.
Old Aug 3, 2004 | 10:22 PM
trueburton's Avatar
well i geuss the bolt is in the wrong spot. and yes i am using a deep socket wrench on the hex part of the bolt, no offense taken. The bolt feels like it is twisting as i try to loosen it. i wasn't sure if it was diffferent or aanything and was afraid to break it, i geuss i'll just wrench a little harder and hope it doesn't snap off. thanks for all the help guys!
Frozer!!!
Jan 19, 2024 04:55 PM
Cleotiz
Jan 6, 2018 08:56 PM
tazs2000
Jul 15, 2017 08:44 AM
Eric-86sc
Apr 3, 2016 03:52 PM
3rdgenparts
Aug 8, 2015 07:09 PM
