injectors_350 vette vs 350 camaro???
Car: '90 Corvette
Transmission: ZF6
I found two bad injectors in my 90 corvette today. 1 at 10 ohms and the other at 12 ohms. My step dad has two out of his 92 350 tpi camaro that tested at 16.8 ohms. But, when I was comparing them I noticed they were a different color (green...not blue) and carried different part numbers......they're both 22# from the factory right?
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Should be the same, yeah.. Are they? who knows.
Usually, I recommend getting new, or a matched set of old ones. (matched on an injector test flow bench).
-- Joe
-- Joe
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Vettes used 22lb. The differences may simply be because they were sourced from a million different suppliers over the years.
