Which runner is better?
Old Aug 4, 2004 | 08:43 AM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
I am looking at getting a either SLP siamese or AS&M. If there isn't much of a difference, the SLPs are a lot cheaper and I would go with them.
Both are untouched and would be new condition.
Old Aug 4, 2004 | 08:54 AM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
I got some SLP's a couple months ago and they are cheap yes. however they are really rough inside and I doubt if they are any larger than the stock runners from the factory. From what I understand, SLP has really let their casting quality slide.
However if you were planning to port them or extrude hone or something then the SLP's have lots of material to take them to very large internal volume.
Old Aug 4, 2004 | 07:11 PM
razor's Avatar
Car: 1992 GTA
Axle/Gears: 4.10
I have the SLP's. IIRC the runner ports are 1.44-1.48ish in diameter which is stock runner diameter. I had to buy some pricey tools to port the runners out to 1.68 all through each runner which is not easy. The extra cost of porting was close to 80 bucks plus the 20 hours needed to port and then polish them on the exterior. Bite the bullet and buy the ASM's. Out of the box they are ready to go.
Old Aug 5, 2004 | 08:20 AM
That's what was wondering, they are expensive though.
Another question:
Does the plenum need to be opened up to match the AS&M runners too?
Old Aug 5, 2004 | 09:42 AM
89Warbird's Avatar
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
I have SLP's but after seeing a set from AS&M, I wish I had bought those instead. You will have to port match either set to the upper plenum.
Linson
Oct 24, 2025 02:00 PM
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Chas91Z28
Oct 22, 2015 10:12 AM
Royal_Z
Sep 30, 2015 08:45 PM
