Whats the first mods to go on a TPI engine?
Old Aug 6, 2004 | 10:46 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
well it looks like I am picking up my 3rd thirdgen next week, 89 iroc 350 TPI. since im new to tpi and all my question i am preparing myself for is.. what are the first mods that need to be taken care of? all i really know first hand is the coolant bypass. does exhaust need to go first? or intake? etc.. thanks for any help in advance.
Old Aug 6, 2004 | 11:35 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
You could benefit with air filters and ported/gutted airbox along with exhaust and headers. I did exhaust first on my 89 Iroc 350 because I wanted a strong muscle car sound. It helps alot especially with headers. Big difference. Before more air can go in, more needs to come out. Once you got decent exhaust and air intake mods, you can benefit from and adjustable fuel pressure regulator. Boost it up to 48-50 psi, especially if you add high flow runners and port match it all. This is good place to start.
The 350 TPI runs good. These mods + good suspension and traction will get you into the 14 flats and possible into 13's provided the engine is in good tune. My car ran 14.02 with 2800 stall on bad street tires with just headers, exhaust, K/N's, and some suspension work. I dont have a fuel pressure regulator.
Old Aug 7, 2004 | 12:53 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
well heres what i have planned so far, edellbrock shorty headers and 3" y pipe, i already have a 3" electric cutout just waiting to be installed, so thats real free flowing exhaust.
i also believe that the intake could be cleaned up quite a bit. and after that, with the adjustable regulator u mentioned, i would get the zex nitrous kit for it for the extra boost into 13's
Old Aug 7, 2004 | 01:40 AM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
travis I have an afpr I'll let you have for cheap I don't plan on using it you just need to get the upper runner gaskets
Old Aug 7, 2004 | 01:54 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
well thanks terrell, first thing though, need to actually get the car, should know for sure tomorrow, and actually ill be buying that box from u befor anything. this rear hatch motor works so i dont wanna rip it out
Old Aug 7, 2004 | 08:38 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
That can be way to much for some cars. I have a set up with basically every thing you can do and that was too much for mine, Too high a FP and your idle will suck, gas mileage will blow and you will have slow reving and a sluggish car. My science proffersor's ZZ4 corvette runs best at 42 psi, I am toying between 42-46 right now. At that much FP you basically are forced to do PROM tuning.
Old Aug 7, 2004 | 10:30 AM
vwdave's Avatar
Those basic mods, then get to prom tuning. I have a mild L98 thats in horrible tune running low 15's. Too many mods without tuning will make the car slower than stock. :\
Old Aug 7, 2004 | 10:47 AM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
I'am with the above post. Go with the exhaust system first. You will see good gains and everything you do on the intake side will be that much better. Allen
Old Aug 8, 2004 | 09:38 PM
no1kicker's Avatar
Car: 1991 Trans Am
Engine: 5.3L
Transmission: auto
Hey kairles how much do you want for the AFPR and what kind is it?
(sorry to hijack the thread)
Old Aug 9, 2004 | 12:50 AM
kairles's Avatar
Engine: 383/LGX
if travis doesn't want it Iet i'll go for 30$ its a crane cams sells for $66.?? witch it what I paid never installed but will be missing upper runner gaskets will be afpr, screw, the little waffer thing, and the torks bit
Old Aug 9, 2004 | 02:10 AM
level's Avatar
Car: 1987 transam
Engine: 383 /w superram
Transmission: 700r4 /w 2800rpm stall
1) cold air kit
2) headers
3) full exhaust
4) aftermarket runners/HEAVILY porting the base plate
5) its time to get into computer tunning
6) 2800rpm stall
7) slicks
8) 210/215 cam
9) afr 195 heads
10) 1.6 roller rockers
i think i took that WAY to far but hey
Old Aug 9, 2004 | 08:39 AM
speed88's Avatar
Car: 1988 Trans Am GTA
Engine: 383
What do you consider too many mods without a tune?? Simply bolt ons like headers, tb, etc will better your e/t's on the stock prom. It has been done a million times.
Old Aug 9, 2004 | 03:31 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
48-50 too much? I saw an article either here on this site or some magazine that did that test and picked up most power. I dont know for sure since I dont have one but okay thanks for the input. I would like to run like 46 psi.
Level
1), 2), 3), and 6) and suspension is what I got on my 350 and should be breaking into high 13's. Ran 14.02 so exhaust really helps TPI cars, and I dont have a chip. Engines just running strong.
Old Aug 9, 2004 | 09:29 PM
no1kicker's Avatar
Car: 1991 Trans Am
Engine: 5.3L
Transmission: auto
That works for me, let me know if Travis doesn't want it. Thanks
Greg
Old Aug 9, 2004 | 09:39 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
I dont want it
Vintageracer
Jan 10, 2020 05:33 PM
The_Phoenix
Sep 3, 2015 10:56 PM
R3500
Aug 17, 2015 12:16 PM
Sanjay
Aug 12, 2015 03:41 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
