stuumped
Old Aug 10, 2004 | 02:24 PM
Jackman5003's Avatar
Car: 1984 S-15
Engine: 1988 Iroc-z 305 V8
Transmission: T-5 (5-speed)
stuumped
it runs semi fine when its JUST started up. but when it warms up it runs rough at idle. and has an OCCASIANL backfire. and also when it warms up and i go to restart it it fires up, almost dies(sometimes does) and then goes back into its rough idle...
should i do a small tune up because the plugs are pretty black(running rich obviously). but what would make it run rich? could it be timeing? if it was a vacum leak wouldn't it run lean? and i've already cheaked for alla that. i can't find the thing to pull the codes and all our paper clips are chrome plated or w/e and i think thats interfearing with the connection on the ALDL. because i already crossed the two terminals and nothing. the SES light just stayed on.
but i do remember that it was code 33 and 36? was it. i think 36, that i pulled. both have to do with the MAF. but nothing happens when i unplug it(the MAF) and start the engine. it still runs the same.
by the way, warmed up, i mean the rad. hoses are hot. i have the light in the truck hooked to the swtich for the fan, which is actually rigged up and the switch isn't beein used(i have it so i touch the wire for the reley to the + batter temerinal to turnt he fan on right now), and that isn't turning the light one even. and that turns grounds at a lower tempature then the regular sending unit for the light. 180 i think it grounds...
Old Aug 10, 2004 | 04:38 PM
kevinc's Avatar
Car: 1982 Z28
Since this isn't regarding a 3rd gen F-body it will get locked soon.
(edit: helpful information deleted)
Good luck getting it fixed before the lock hits...
Old Aug 10, 2004 | 11:22 PM
Car: 1984 S-15
what the ****??? how is this not thirdgen related??? its a ****in 3rd gen engine isn't it? *** damn this bourd ****in sucks...
what about s10 wildside??? huh? mikes on here all the time helping people out...noone tells him bout this....
not to start anything but this is about hte 3rd post of mine that got locked...so what the ****...
