Fuel rail O-ring sizes???....
Old Aug 12, 2004 | 02:06 AM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
Anyone know what size the O-rings are for the fuel rail? Not the fuel injectors, but the actual tubes for the fuel rail.
The AP stores don't carry O-ring kits and it appears Fel-Pro only makes injector O-rings. I already have those.
I have a source for O-rings, I just need to know what the correct size is so I order the right ones.
TIA
Old Aug 12, 2004 | 01:03 PM
91Z28-350's Avatar
I don't know the size, but I'd just grab a few packs of the Help! o-rings. They have them in there. I know I used them for the fuel rail, as well as for the fuel filter. Get the "brown" ones, not the "black".
Old Aug 13, 2004 | 01:35 AM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Re: Fuel rail O-ring sizes???....
TIA
Try this web site. I believe they have some.
http://www.hotrodlane.cc/
Old Aug 17, 2004 | 06:45 AM
mwfrels's Avatar
Car: '86 Z28
Engine: SDPC TPI 350
Transmission: WC T5
Axle/Gears: 3.23 posi
Fuel Rail O-ring sizes
Cross communication tubes: 2-110
Return line @ Regulator: 2-109
Stub aluminum tube between Regulator and Rail: 2-012
If you have a cold start injector there are two more o-rings where it plugs into the back of the driver side rail. I don't have one on my car but I can look up the sizes of them if you need.
I use 70 Durometer Viton o-rings to redress my rails.
Old Aug 31, 2004 | 10:44 PM
formulaman's Avatar
You can order the complete set from GM for not too much money
Old Sep 1, 2004 | 10:06 AM
Ringmaster72's Avatar
Car: 1989 IROC
NAPA has them--I bought them from NAPA last year
Andrew6.688
Dec 13, 2015 10:59 AM
toronto formula
Nov 10, 2015 06:17 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
92projectcamaro
Aug 6, 2015 01:20 PM
