Runner dent
Old Aug 11, 2004 | 01:58 PM
Goumba T's Avatar
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
Runner dent
Well, here's one of my dumbass moments... did a search and turned up nothing.
I was trying to do my valve guide seals today when I ran into a stubborn bolt while in the process of removing the valve cover (on the intake, holding down FI/Alt harness) that penetrant wouldn't help. So I decide to call on the grace of a BFH. Tap, tap, nothing. Swing, ricochet, right into a runner tube. Actually did it twice (first time didn't notice it).
Its not a big dent, but its noticably ugly. Will this hurt performance in any way? Its such a small dent I'm guessing no (I took a digital photo but all I could see in it were the marks form the hammer).
I probably know this answer already, but is there any way to fix this?
Old Aug 11, 2004 | 02:09 PM
jwscab's Avatar
Engine: Many
Transmission: Quite a few
i managed to push out a dent in a runner using the boxed end of a wrench, but i don't remember the size, since it was nice and rounded(craftsmen), i just kinda pushed it into the runner, to the dent and tapped lightly with a hammer, now, you can see where the dent was, but its not dented anymore. i think i might have even had a blanket or something under it to kind-of prevent it from hitting a hard surface when i tapped it out. i picked the wrench cause it just fit into the runner, and stopped once it hit the dent.
Old Aug 13, 2004 | 11:49 AM
91RS5speed's Avatar
Car: 91 RS
Axle/Gears: Auburn Pro / 3.42
depending on the size of the dent more than likly it wont do anything
Old Aug 14, 2004 | 12:02 AM
Goumba T's Avatar
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
Thanks for the responses. I'll try the wrench things when I take them off.
Old Aug 16, 2004 | 11:59 AM
rockind78's Avatar
Any musical instrument repair place should be able to do it.
Old Aug 16, 2004 | 12:49 PM
Markgyver's Avatar
Car: 1992 K15 Blazer
Engine: 383 with TPI, Edelbrock Intake & Runners, 24lb svo injectors, 730, $8d
Jim Performance will push a bearing the size of the runner through the tube and it will pop out any dents
Old Aug 16, 2004 | 04:58 PM
omcrider's Avatar
Car: 1988 GTA
Engine: 5.7L/L98
ebay often sells the steel ***** for this job. I just saw a set go unbid for $20
Old Aug 16, 2004 | 08:45 PM
dj haf's Avatar
Car: 1990 IROC-Z
Engine: 350 L98
when i had my engine rebuilt, my mechanic left a nice freakin' dent in one of my runners. i dont know if it affected the performance, but i really don't care because i had the HSR waiting to be put on. i wouldnt spend a dime fixing anything with the stock intake... i'd just get better runners, or replace the tpi with something better. just my .02
Old Aug 17, 2004 | 09:34 AM
Goumba T's Avatar
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
That's neat, never heard of that. What keywords do I search for?
Old Aug 17, 2004 | 09:54 AM
omcrider's Avatar
Car: 1988 GTA
Engine: 5.7L/L98
I ran across them just using "TPI runner" Maybe narrow it with TPI runner repair. They are not always there however.
Old Aug 31, 2004 | 10:32 PM
formulaman's Avatar
The large ball bearing trick works great!
Old Aug 31, 2004 | 11:39 PM
Goumba T's Avatar
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
Been watching eBay with no luck. What size do I need and where could I go to just get a plain ball bearing to do this?
Old Sep 1, 2004 | 12:14 PM
dj haf's Avatar
Car: 1990 IROC-Z
Engine: 350 L98
buy a new set of aftermarket runners if you want to stay with the tpi.
Linson
Oct 24, 2025 02:00 PM
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
meeklay812
Oct 1, 2015 03:46 PM
Royal_Z
Sep 30, 2015 08:45 PM
