TPI question (i did a search)
Old Aug 12, 2004 | 11:12 PM
steves86TA's Avatar
Car: 2008 silverado
Engine: 5.3
Im thinking about converting from my cc q-jet to a tpi system. My question is will my factory altenator bracket, and airconditioning bracket fit the tpi mainfold. I think the ac one will because it takes an intake bolt hole. But the altenator one will it? if someone can please post a pic of where there tpi one bolts too, or if there is a provision for it please let me know
Old Aug 12, 2004 | 11:19 PM
87350IROC's Avatar
Car: 87' IROC
This is for the '87 v-belt setup. In any case it should give you an idea. The alternator bracket attaches to the water pump and the first bolt for the passenger side runner. The a/c bracket is more complicated but it attaches to the front of the intake manifold with two bolts. Do you have a pic of your current setup?
Old Aug 12, 2004 | 11:39 PM
steves86TA's Avatar
Car: 2008 silverado
Engine: 5.3
thank you for the quick reply. On my car the Altenator bracket attaches to the intake manifold via a provision on it, heres a pic of that
steves86TA's Avatar
Car: 2008 silverado
Engine: 5.3
and the ac bracket seems to be the same... heres a pic of that... ill try to get a better pic of the altenator bracket
Old Aug 12, 2004 | 11:46 PM
steves86TA's Avatar
Car: 2008 silverado
Engine: 5.3
heres 2 more better ones, Mods please allow these pics, you can delete after i figure it out please
Old Aug 12, 2004 | 11:47 PM
steves86TA's Avatar
Car: 2008 silverado
Engine: 5.3
one more
Old Aug 12, 2004 | 11:51 PM
87350IROC's Avatar
Car: 87' IROC
I agree, the a/c bracket looks the same. It looks like you will have a get a TPI alternator bracket. It shouldn't be hard though. You can prolly find one in a yard, ebay, or this site.
Old Aug 12, 2004 | 11:52 PM
steves86TA's Avatar
Car: 2008 silverado
Engine: 5.3
one of the bolts on mine bolts to the waterpump, i wonder if i can modify mine to blot to the tpi intake, or does it even bolt to the tpi intake?
Old Aug 12, 2004 | 11:59 PM
87350IROC's Avatar
Car: 87' IROC
circled is where the alternator bracket attaches
Old Aug 13, 2004 | 12:01 AM
steves86TA's Avatar
Car: 2008 silverado
Engine: 5.3
so there is no way that itll bolt up. hmm o well thanks for all your help, and i hope to get converted soon. Now you dont know about anybody that is selling a altenator bracket do you
Old Aug 13, 2004 | 12:04 AM
11sORbust's Avatar
I bought the alt braket from GM. It doesn't cost much if you know someone that works at the dealer...
Old Aug 13, 2004 | 12:07 AM
steves86TA's Avatar
Car: 2008 silverado
Engine: 5.3
my dads a shop foreman for a chevy dealer, so we will see how much it is. Also thanks again for all your help it is really appreciated
Old Aug 13, 2004 | 12:08 AM
steves86TA's Avatar
Car: 2008 silverado
Engine: 5.3
also does anybody have the part #?
Old Aug 13, 2004 | 12:34 AM
11sORbust's Avatar
check here..
https://www.thirdgen.org/techbb2/sho...5&pagenumber=1
Or just order an upper alt braket for an 85 trans am/TPI..
Old Aug 13, 2004 | 12:35 AM
steves86TA's Avatar
Car: 2008 silverado
Engine: 5.3
thank you i appreciate it
Old Aug 13, 2004 | 07:04 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: TPI question (i did a search)
If you didn't allready buy the TPI setup, look into a hsr instead. Don't make the same mistake a lot of us have.
-- Joe
Old Aug 13, 2004 | 09:34 AM
11sORbust's Avatar
I totally agree, in fact the HSR cost less. Just use a tpi harness and puter.
Old Aug 13, 2004 | 11:41 AM
steves86TA's Avatar
Car: 2008 silverado
Engine: 5.3
honestly i would look into the hsr, but im 16, with no job, and im getting a really good deal on a setup, minus a few things from a member on here
Old Aug 13, 2004 | 12:56 PM
87350IROC's Avatar
Car: 87' IROC
Steve, where are you located? Good luck with the swap. And don't be afraid to pm me with any other questions.
Old Aug 13, 2004 | 01:56 PM
steves86TA's Avatar
Car: 2008 silverado
Engine: 5.3
im rancho cucamonga Califronia, and thanks, but i may not be doing the swap right now anyways
Juneb1022
Firebirds Wanted
Oct 12, 2015 08:12 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
