Street Ram
Old Aug 13, 2004 | 12:07 PM
Ffej's Avatar
Car: 91 Formula
Transmission: 700-R4
Street Ram
Is the CalMap software required for the street ram setup?
Old Aug 14, 2004 | 07:44 AM
Chrome's Avatar
Car: 92' RS Camaro
I am assuming you mean stealth ram. (Mfg by Holley). Anyways the Calmap software is the software for the Holley Commander 950 computer I believe (someone correct me if I'm wrong).
If you don't do any cam/heads change I'm confident you can get by w/ the stock cpu for awhile. Start doing anymore modifications then you will have to look into tuning the FI either by burning proms for the factory computer, or getting a dfi system like the Holley Commander 950 computer.
Old Aug 17, 2004 | 09:31 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Streetram is a system too - by accell it reminds me of the FAST setup because it is long tube runner dual plane intake and it looks just like the TPI except it is noticeably larger (better flowing). Whether it is equal to the FAST system I cannot say.
I imagine you'd need the calmap software if of course you don't already have TPI EFI.
Old Aug 17, 2004 | 10:53 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
The Street Ram is a beefed up TPI system sold by Accel. It consists of the Accel base, runners, and ported plenum. It's meant to be used in TPI retrofits.
The Calmap software is the interface used by the Accel DFI systems. You wouldn't need Calmap/DFI unless you're doing a TPI retrofit. And it would probably be more cost effective to just use a GM ECM and nice aftermarket wiring harness.
Old Aug 17, 2004 | 11:56 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Dont go for calmap, I did it years ago and I can tell you that a GM box is the right way.........If you have much $$$ go for bigstuff3....
/N.
Old Aug 19, 2004 | 11:43 AM
Ffej's Avatar
Car: 91 Formula
My car is TBI. The whole setup includes wiring harness and an ECM I believe. Would an aftermarket chip work in it thats meant for the original GM?
Old Aug 19, 2004 | 12:13 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
Calmap/DFI doesn't use chips. The Calmap software is used to edit fuel and spark tables in the DFI box.
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
mfp189
Sep 27, 2015 09:25 AM
