tpi swapping across year models
Old Aug 14, 2004 | 09:12 AM
88tatpi's Avatar
Car: Z28HO/TA/Alfa Romeo
Engine: 305-350-502
Transmission: 700R4-5speed
Hello Everybody!
My situation is I am installing a 1989 305 TPI injected motor into a 1988 Chevy truck(700R4 2 wheel drive C-1500)
and using the wiring harness from a 1988 Camaro Z28.
I have both computers; the Z28's and the T/A's.
My concerns are the '88 Camaro(wiring harness) has the extra idle fuel injector and the T/A motor does not.
Anyone know if by using the T/A computer and just leaving the wires isolated that go to the idle fuel injector all will be well as far as the computer goes. Are there additional wires to deal with? open? short? bypass? remove? ground?
I must say the articles at this website are far more important and informative than all the books I have purchased,begged and/or borrowed! You guys are the greatest!
Old Aug 14, 2004 | 11:16 AM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
The extra wires are for the cold start injector. Nothing to do with idle.
Just leave them off, they aren't even connected to the ECM. Make sure you use a bin from the newer version, it uses the computer to enrich things for startup, instead of the CSI.
This and the throttle body question you posted would be more appropriate in the TPI forum though. You may want to ask a moderator to move it for you, or repost over there.
Grant2k
Jul 10, 2018 04:01 PM
Fast355
Dec 2, 2016 06:33 PM
jharrison5
Aug 19, 2015 05:53 PM
Sanjay
Aug 12, 2015 03:41 PM
Fronzizzle
Aug 9, 2015 01:15 PM
