maf and injectors need2 b matched ?
Old Aug 16, 2004 | 11:43 AM
greenfrogg's Avatar
Car: 89 FORMULA355 80 TURBO TA 355
Engine: 355 tuneport 355 chev CARB
Transmission: 700 350
do i have 2 match my injectors with my maf or will any maf work ? thank s in advance.:hail:
Old Aug 16, 2004 | 11:56 AM
88fbird's Avatar
Car: 84 S-10:(
Your chip should match your injectors. Your MAF shouldn't matter.
FBird
Old Aug 16, 2004 | 02:11 PM
greenfrogg's Avatar
wasnt sure a mustang guy told me they had to match and i am in the process of chasing code 34 ,so iwas goin to buy 1 and wanted the right 1 the first time ...thanks 4 quick reply.:hail:
Old Aug 16, 2004 | 06:13 PM
Guest
Guest
Posts: n/a
Thats what you get for listening to those Ford clowns.
The Ford EEK system has few similarities to the GM system. I'd try to not take too much of their advice, stick to the knowledgeable guys around here.
Getting a new MAF or injectors? Curious...
Old Aug 17, 2004 | 04:58 PM
greenfrogg's Avatar
getting the maf replaced , has a bosch on it now .it throws code 34 . i think because, because i touched a sensor in side . kind of a expensive guess . its weird cause sometimes the car will fly , and other times it will bogg.
Old Aug 17, 2004 | 08:56 PM
Guest
Guest
Posts: n/a
Sounds like a code 34 issue. Can you swap in someone else's MAF and see if it still does it?
Check for vacuum leaks. Make sure the TPS is set right. Unfortunately just because you get a MAF code, doesnt mean that is the problem, could be a number of other things causing it.
Old Aug 18, 2004 | 10:15 AM
greenfrogg's Avatar
tps worked fine before engine change so i wouldnt think that.vacuum on the other hand ,could ya tell me what the skinny plastic tube vacuum is 4?it looks like it runs into firewall and along the wiring harness. its hooked up ,just dont know if it needed thanks:hail: :yourock:
Old Aug 18, 2004 | 11:43 PM
350tpi5speed's Avatar
Car: 2000 Camaro Z28
Engine: 5.7 LS1
Transmission: 6 speed
i think the one you are talking about goes to the heater hose. any one know why? just curious.
Old Aug 19, 2004 | 03:59 PM
greenfrogg's Avatar
well i un hooked it and it ran better, butt still have problem heat quit because of this
New2Chevy
Oct 4, 2015 11:27 PM
BAMiller
Sep 14, 2015 06:38 PM
mike40sm2
Sep 1, 2015 02:15 AM
Bert87
Aug 23, 2015 03:50 PM
ezobens
Aug 19, 2015 10:29 PM
