does this sound like a good setup?
Old Aug 17, 2004 | 11:37 PM
FireBird88's Avatar
GMPP L98 Short-block
Phase 2 SB Chevrolet Bowtie Cast Iron Cylinder Heads (as-cast)
LT4 Hot Cam SBC GM Hydraulic Camshaft Kit
TH350 w/ 3500 stall
Stock TPI w/ SVO #30's
will be swaped for a HSR as soon as the $ is here?
does that sound like a good setup?
any guess what it would run in the 1/4Mi?
TIA
Old Aug 18, 2004 | 06:29 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: does this sound like a good setup?
TH350 w/ 3500 stall
TIA
Compression ratio? Head flow numbers? Exaust ?
-- Joe
Old Aug 18, 2004 | 07:08 AM
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
I found flow numbers....Hope you didnt have to pay much for them
.200 130/100
.300 177/119
.400 205/123
.500 225/123
That exhaust will kill your power
Edit: sounds like the convertor is a little big also...
Old Aug 18, 2004 | 04:48 PM
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
Converter Is WAY TO BIG
Heads Don't Flow Very Well
Just my .02
Old Aug 18, 2004 | 07:56 PM
FireBird88's Avatar
this was going to be a much better motor.
but had a lot of damage w/ hurricane charley.
it was going to be a twin 60-1 turbo.
but now the turbos got pushed back a good bit.
so now i gotta finish the motor w/ about 1/3 the budget.
i have the short block and th450 and converter.
so i need a cam and heads that make good power and work w/ what i already have.
what would you guys do?
thanks again
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
gta90
Sep 15, 2015 04:00 PM
db057
Aug 22, 2015 08:17 PM
midias
Aug 22, 2015 01:42 AM
