Crank Case Pressure
Old Aug 21, 2004 | 02:43 PM
Crazy_Joe's_Bro's Avatar
Car: '85 IROC-Z
Transmission: 700 R4
Crank Case Pressure
I am having a problem with positive crank case pressure. The PCV valve is new and has plenty of vacuume. However I still have oil vapor getting blown up the PCV breather tube and possibly out an engine seal. Does anybody know how to stop this?
Old Aug 22, 2004 | 03:17 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Welcome to thirdgen.org!
Seems like you may have excessive blowby, generally you need to rebuild it.
How many miles on the engine?
Old Aug 22, 2004 | 03:39 PM
Russ-So Cal's Avatar
You need to have a leak down test done to your engine. Most likely, your rings are worn on at least one cylinder to the point that it is getting a lot of blow by. Only a leak down test will tell for sure.
Old Aug 31, 2004 | 10:42 PM
formulaman's Avatar
Give the leakdown test a shot. The stock evac system is pretty limited though
Cornholio7979
Sep 20, 2018 02:31 AM
mddaniel
Sep 8, 2015 05:16 PM
Justin92GTA
Aug 27, 2015 11:16 PM
TheExaminer
Aug 26, 2015 04:59 PM
