BATTERY negative wire placement
Old Aug 21, 2004 | 09:30 PM
irocnroll89's Avatar
From: previously OKINAWA JAPAN,georgia, now new england
Car: 1989 IROC--1989 T/A
Engine: 5.7 TPI in both
Transmission: W/C T-5 in both
Axle/Gears: B/W 3.27 in both
I am puttting in a new ground wire on the 1989 T/A. I need to know where the battery ground wire bolts to the engine. The wire was never installed when i bought the car..... and it is a T/A so the battery is on the "wrong" side of the car, compared to the IROC. Thanks will be installing the new positive wire whilst i wait for the answer. thanks shawn
Old Aug 24, 2004 | 08:51 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
well i just yanked the engine out of my '91 TOI and the neg batt cable was attached behind the AIR pump or A/C, can't recall for sure, but there should be a bolt hole right in that area. hopefully that helps. for someone who just took it off (last weekend), i don't seem to remember much, but i'm not at home, either, where i can go look at it...
KAM
Old Aug 24, 2004 | 09:53 AM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
it should bolt up on the driver side cylinder head in front.
Old Aug 25, 2004 | 06:53 AM
Car: '91 Z28
Axle/Gears: 323's
exactly - what he said.
KAM
Old Aug 25, 2004 | 05:26 PM
DeWynter's Avatar
Mine is on the bottom by the air pump.
Old Aug 31, 2004 | 09:59 PM
formulaman's Avatar
On my 91 bird, it is bolted to the front engine accessory aluminum bracket on the lower driver's side.
Street Lethal
Apr 30, 2019 12:14 PM
GTAman
Mar 15, 2019 11:40 AM
Ikes 91Z
Dec 9, 2015 03:49 PM
Jae992
Aug 27, 2015 09:07 AM
