Missing when cold
Car: 88 GTA
Transmission: 700 R4
Missing when cold
I Have read many posts here that have helped me out a bunch, but now I'm stuck. I have 2 issues I'm trying to solve in my 1988 GTA ( 5.7) . First one is Car misses when cold, unless your get into to the throttle then it wakes right up. After some drive time the miss goes away. I Have replace wires, cap , rotor, plugs, control Module and pick up coil. ( main with MSD) Throttle is much smother and some of the missing is gone, but some remains but only after cool down. I'm running out of ideasand $'s .. maybe EGR, 2nd issue is after running long peroids on days above 80 degrees the tank seems to build to much pressure and starts to stumble off the line. And I smell gas every now and then like the canister is not working. I replace the canister and silonoid plus the pressure valve but still get the smell. After releasing the tank pressure the car seems to run righ again for awhile. ???????????????????????????
thanks for ANY ideas.. Joined: Feb 2001
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Welcome aboard! You may have better luck in the TPI forum since you have an L98. I will move this thread so that you will get better repsonses.
tyeo098
Nov 30, 2015 06:27 PM
