HSR question
Old Aug 27, 2004 | 01:58 PM
hitman's Avatar
Car: 1992 25th Ann. Z28
Engine: 5.7 TPI - Stock
Transmission: th700 r4
HSR question
I am thinking of replacing the stock TPI and convert to HSR. Looking at the set up in the Summit catalogue (SP), do I need to get the wiring harness and new throttle body?? If I am reading it right the base and plenum are around $600.00 and their complete setup is $2200.00. Maybe I'm not reading between the lines, what am info am I missing? Help please
Old Aug 27, 2004 | 05:22 PM
irocing's Avatar
Car: 1987 IROC-Z
Engine: stealth ram injected ZZ4 350
Transmission: 700R4 w/3200 stall
If you already have a TPI unit then all that you need to really get is the HSR, plenum, base intake, and the fuel rails.the rest of the parts are up to you, if you want to get new injectors and a new throttle body then go for it. But you don't need to buy the wiring harness and everything because you already have one of those, i think that the only problem you are going to run into is that the HSR is EGR delete. Best of luck man, any other questions just let me know, I already went through all of that mess myself, it really isn't that bad.
Old Aug 29, 2004 | 01:50 AM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Re: HSR question
If you buy it from summit check out thunder racings prices first. I believe they are 20-40 dollars cheaper. Summit will price match if you tell them TR's price. Or buy it from TR.
Old Aug 29, 2004 | 11:10 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Remember who sponsers this site, Thunder Racing.
Old Aug 30, 2004 | 12:29 PM
hitman's Avatar
Hey IROCING, did you feel the extra 20-30 HP as described in the advertisement?? Another question.. how much if any programming, if any, is required??
BTW.. nice lookin engine bay. I hope to have the same soon.
Old Aug 30, 2004 | 12:50 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Transmission: Slipping
I personally felt a little loss of torque, but it pulls all the way to 5300 RPM now. Tuning was what I expected, it fattened up in the low RPM range and got really lean over around 3000 RPM. But 12 chips later I'm back to 21 MPG.
Old Sep 4, 2004 | 10:18 AM
irocing's Avatar
Car: 1987 IROC-Z
Sorry that it took so long for me to get back to you, I lost alot of low end but i gained alot of high end, I just didn't put the HSR on, I did alot more then that. I now have a ZZ4 short block, ported and polished heads, LT4 hot cam kit and i also have the headers but those are not on the car yet. If every thing goes well, i will be putting the headers on next weekend, going to the NHRA U.S Nationals this weekend, after the headers are on I will be getting the car Dyno Tuned and i'm expecting at least 400 horses out of this motor. Thanks for the clean engine bay comment, but the car is far from done, alright everyone, have a good weekend, i have to get on the road for the races.
355tpipickup
Alternative Port EFI Intakes
Aug 29, 2015 10:47 PM
ASE doc
Aug 25, 2015 09:14 AM
trevor1010
Aug 24, 2015 11:29 AM
355tpipickup
Aug 22, 2015 06:06 PM
redmaroz
Aug 16, 2015 11:40 PM
