TPI idle problems PLEASE HELP!!!!
Old Aug 28, 2004 | 07:27 AM
rhondas92gta's Avatar
Car: 1992 GTA
Engine: 5.7
my 92 GTA just out of the blue won't idle. The car runs perfect as long as you don't have to idle. There are no codes in the computer. My husband created a vacuum leak @ a vacuum port by the map sensor and it idles with this leak and runs ok, only problem with that is my a/c won't blow out of the vents with this vacuum leak he created. If there are no codes, could it still be possible the iac motor could be bad? PLEASE help as this is driving me crazy!!!!
Old Aug 28, 2004 | 06:54 PM
88fbird's Avatar
Car: 84 S-10:(
Take out the IAC and see if it is covered in junk. If it is, that is probably your problem. Clean it and the throttle body like the tech article says. Then you will know if the IAC is your problem or not.
It is a painless procedure.
Good luck,
FBird
Old Aug 29, 2004 | 01:37 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
Often it's an IAC problem.
If you have a ScanTool, Diacom or some other data logger, you can monitor the IAC counts. At idle they should be in the 20 range and the numbers should rapidly rise and fall as you blip the throttle.
Remember, it's all about the numbers, so investing in a data logger is a extremely worth while investment. You'll end up using it so often you'll wonder how you ever got along without one.
Jake
Old Aug 29, 2004 | 09:55 PM
Car: 1992 GTA
Engine: 5.7
thx JakeJr.One of my husbands buddies has a snap on scanner which should tell us what we need to know.
Infested
May 22, 2018 11:56 PM
Wade787b
Sep 29, 2015 01:15 PM
db057
Aug 22, 2015 08:17 PM
Sanjay
Aug 12, 2015 03:41 PM
