88 tpi setup on a older block ?
Old Aug 31, 2004 | 07:26 PM
85 lg4's Avatar
Car: 89 TA
Engine: Fast !!
Transmission: slipinslide auto
I have a TPI setup and I want to keep it on the car but replace the tired old 305 with a 350 4 bolt main/ all forged insides and motown heads I have.
Now this was in my old monte with a victor jr and a 750 on it ,can I just take the manifold off and bolt my TPI on top, put in some inj and a prom from a 350 car?
The unit is bolted to the 88 centerbolt valve cover car and the heads I have on the new engine are old style perimiter bolts
just thought I would ask before I have a mess. I do understand it will not make as much hp with the tpi that is ok. looking for a good driver
Old Sep 2, 2004 | 11:06 AM
86BirdSE's Avatar
Car: 1986 Pontiac Firebird S/E
Engine: LG4 TPI Conversion
Axle/Gears: 3.42 SLP Posi 10 Bolt
I'm doing, more or less the same thing.
I elongated the center base manifold bolt holes. Everything else bolts right up.
For a 350, use injectors form a 1991-1995 "Tuned Port Injection" 3800 v6. Got mine at the local Pick-n-pull. They are the same flow rate as the stock 350. With cleaning, flow matching and new O-Rings I've got about $85 invested in them.
AN AFPR and your stock 305 injectors would also work too.
Forgot to add that you'll need a 350 knock sensor too.
Old Sep 10, 2004 | 02:57 PM
ChevelleFan's Avatar
Car: '70 Chevelle, '63 Corvette
Engine: 383, 327
Transmission: B&M 700r4, Muncie M-21
How did you elongate the holes? I'm going to need to do this to mount my '87 TPI base on my '71 heads. Just get a dremel/die-grinder and elongate till the bolt-n-washer sits flat? Is it possible to mess it up bad?
Also, where did you get 8 injectors cleaned, flow-matched, and new o-rings for $85? I've casually looked around, but it seems like places want $20/injector.
-Dave
Old Sep 14, 2004 | 12:02 PM
just2quickz28's Avatar
Car: 86 IROC
I had this done at my local machine shop, its only 4 bolt holes, it cost me a 12 pack..... but heres the thing when you install the intake use lots of silicone, the enlongated bolt holes are prone to leak, so take care of it before it starts..... other than that no problems.
gta90
Sep 15, 2015 04:00 PM
masonta
Aug 31, 2015 10:14 PM
Sanjay
Aug 12, 2015 03:41 PM
BBSDesigns
Aug 11, 2015 07:39 PM
squiggy2
Aug 9, 2015 09:30 PM
