What would cause engine to stall when stopping at red light?
Old Sep 2, 2004 | 08:47 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I finally got my 395 cu in stroker in and am doing some tuning I have the 165 ECM using a modified 6E definition file. Check out the signature for other info on the engine.
Does anyone have a suggestion of why it stalls out? I have gone thru the intake stuff and have located and elimenated the vacuum leaks.
Old Sep 2, 2004 | 09:22 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I'd keep on eye on IAC counts when you close the throttle coming to a stop.
Most likely it is in the tuning, might get better luck on the PROM board, since it probably ran okay with the other motor?
Old Sep 2, 2004 | 10:02 PM
z28monster's Avatar
Car: 86 IROC-Z
Axle/Gears: 3.42s/posi/disc
prolly not it but it could be your torque converter not unlocking all the way.
Frozer!!!
Jan 19, 2024 04:55 PM
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
