aftermarket TPI tubes
Old Sep 5, 2004 | 07:12 PM
arejay86's Avatar
Car: 1988 IROC-Z
Engine: 305 TPI 30 over
I've seen aftermarket tubes for the TPI, like larger diameter by i think a half in or so, sumthing like that, not real sure who makes them, thought i saw them in jegs, anyway, to the question, anyone who was bought them and installed them, do you see an improvement in performance, if so, where, like bottom end or up top around 4500 to 6 grand? just curious, was thinkin about buying a set, but would like opinions first thanks a bunch
RJ
Old Sep 5, 2004 | 08:46 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
The runners I have installed are from AS&M(Arizona Speed & Marine) that look stock but are large tube runners. Hope that helps.
Old Sep 6, 2004 | 01:23 AM
Morley's Avatar
On a stock 305 TPI...no improvement, but combined with a larger base, ported plenum and headers....vast improvement.
Old Sep 6, 2004 | 04:45 AM
vexter's Avatar
Car: '88 Iroc
Axle/Gears: 3.45
provided you put some work into porting them and assuming you want to keep the stock plenum, the arizona speed & marine runners (tubes as you called them) are the best you're going to get. expect to open your pocketbook for them. their semi-siamesed runners are $475.
Frozer!!!
Jan 19, 2024 04:55 PM
Chiknhawk
Aug 23, 2015 05:54 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
