Voltage drop (short) when I turn the key
Old Sep 15, 2004 | 07:02 AM
Ringmaster72's Avatar
Car: 1989 IROC
When I turn the key to start my car, the voltage drops to like 8 volts and the car does not turn over or click or anything. It does not do this everytime, but is doing it a lot of the time. I realize there is a short because of the voltage drop as well as a white wire with a red or pink stripe that gets really hot. I know that a bad starter can cause a short, but I hear a clicking under the dash when this happens. So if the starter is causing the short, would something under the dash make any sounds? Or is there a relay switch of some kind under the dash that could be bad and causing the short?
Jae992
Aug 27, 2015 09:07 AM
TheExaminer
Aug 19, 2015 10:07 PM
Bryan F
Aug 18, 2015 02:28 PM
tnrednneck
Aug 13, 2015 08:57 AM
Kaweh
Aug 9, 2015 02:54 PM
