Hard cold start
Old Sep 15, 2004 | 07:45 AM
Ruiny's Avatar
Car: 86 trans am
Transmission: T 56
Hard cold start
I have a 86 TA with a 350 TPI
I have changed most of the sensors when I had the motor rebuilt.
The fuel pressure does drop off when the car sits overnight but even if I turn the key to acc and let the pump charge up the lines it still takes 6+ tries to get it to kick. It does hold pressure for several hours though .
I have set the base timing and there is no SES light on.
I think this problem may have held over from the old 305 because some times (most of the time it was a real hard cold start).
And by cold start I mean first start in the morning it could be a 100 deg outside with the same problem.
Old Sep 15, 2004 | 08:46 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
It could be the chip, I know the ARAP chip starts a little hard. Or you might consider the "Cold Start injector" could be bad.
John
Old Sep 15, 2004 | 10:01 AM
bobsroc's Avatar
Car: 1987 IROCZ
What is your base timing set at with ECM unplugged? Just curious, timing set incorrectly will cause a hard start.
Old Sep 15, 2004 | 10:33 AM
Ruiny's Avatar
Car: 86 trans am
Transmission: T 56
I set the base timing to 10 deg. this seemed to make the car run the best with crisper throttle responce.
I removed the cold start injector because i thought it was the cause of my fuel pressure leak. But it turned out not to be.
Thanks again
Wade787b
Sep 29, 2015 01:15 PM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
apie2546
Aug 10, 2015 05:43 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
