88/91 that won´t start
Old Sep 20, 2004 | 11:47 AM
Lunkan's Avatar
Car: Pontiac Turbo TransAm
Engine: Buick 3.8L
Transmission: TH400 Switch Pitch
I was supposed to help a friend with cam/head/TC swap. To make a LONG story short:
The car is a 88 GTA that´s been converted to 91 MAP. When I got it here, the +cable was almost burned apart and had cut a 5cm long hole in the header. It ran like crap, and there was a HUGE vacuum-leak because of wrong choosen hoses. These two problems are solved.
Because of LOTS of problems, the TC and heads (TF Gen.1) never got replaced. The cam is a Crane HR-284-2S-12, the rest is stock.
Now the car won´t start. It ALMOST starts, but never fires up.
- battery is fully charged
- good spark
- connections double checked
- distributor correct installed
- valve adjustments made
- it gets fuel (on the 3rd set of plugs, they "drown" of all cranking)
What was supposed to take 3 days, now has taken 4 months because of problems, problems, misfitting, problems, lack of motivation etc. etc.
Please, help. I´m all out of ideas. I´m not sure if the owner would appreciate that I put some C4 under the car (which is not TOO far away).
/Andreas
Old Sep 20, 2004 | 01:44 PM
Lunkan's Avatar
Engine: Buick 3.8L
I went out to check the injectors, maybe they where bad. Nope, all of them was 16.8-17.3
A friend called me and I was going to let him listen over the phone, and then something happened that didn´t before... A large detonation which I THINK came from the intake. I switched the plugs 180deg, without any progress.
PLEASE, this is killing me, at least the detonation almost gave me a heartattack
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
