Need to buy new MAF
Car: 1987 trans am GTA - sold
Need to buy new MAF
My MAF is throwing engine codes - cannot reset without the code getting thrown again. The car surges at idle - rising up and down. I took the screens out several months ago - probably messed it up then. The car is an 87 l98 car so the MAF is not exactly new.
The question is - what to buy? TPIS sells a bosch unit for $400 - while Oreilly's sells a reman for $165. What have you guys done? From what I can read on the posts - the granitelli is over rated.
I also plan on more mods in the future - like a cam - heads - intake package.
Thanks for any help!
DJP87Z28, thanks for the help.
I have done the search and cannot find it. If you have any info as to where these guys are that would help.
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
Take a look at the ECM/ESC ground wires on the back of the left cylinder head. My crimped ring terminal was corroded and cause me no end of problems that were much like the symptoms you report.
I crimped/soldered on a new connecter and put the ground back on and my problems were solved. But now I think all probs are gound related
But, it's just too simple and easy to check not to do this and eliminate it as a potential problem. Cost me 2 weeks of down time and lots of money to find out it was a corroded connection that cost $.10 to fix.
Live and learn I guess.
But, it's just too simple and easy to check not to do this and eliminate it as a potential problem. Cost me 2 weeks of down time and lots of money to find out it was a corroded connection that cost $.10 to fix.Live and learn I guess.
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Buy the remaned MAF, its most likely a Bosch unit to start with.
I just bought a remaned MAF at AutoZone, it works great. However, I'm going back to my ported MAF, so if you live in SE Michigan, I will sell it to you.
if you look at the back of the engine bay next to the master cylinder you will see three relays the first is your fuel pump relay, second is your maf power relay, third is your maf burn off relay. though i do agree with the reply earlier that the iac and tps may need to be adjusted if you haven't done so already. your tps for that year is still adjustable not fixed. also i was wondering what is the code or codes you are recieving from the ecm itself if it is a high or low voltage to the maf the it is usually the power relay but hopefully these will help so you will not have to chew up all that money.
Hey everyone, thanks for all of the input here. This community is invaluable if you are going to own a third gen car.
I ordered a reman maf and it should be here today. My friend ordered it through his shop. I will just put it on and if everything works again I know what the problem is. If things are still the same I can take it back and look into all of the suggestions that have been posted here.
Tom
Tom
BumpaD82
Feb 26, 2016 02:57 PM
MikkoV
Sep 9, 2015 04:25 PM
