Can i get into the 13's tonight???
Car: 91z
Engine: 5.7 TPI
Last time out went best of 14.14 @ 98.6 with 2.13 60ft. Left pretty easy then floored it and it went ok i guess. This time i have nitto DR and on the street the hook amazing!! I will post results later tonight. What psi should i run and it should get a 13 right??? Is it possible for a 1.9 60ft?
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
I don't know size nitto DR's you have so its kinda hard to determine an effective psi setting for them. You're currently at 14.14 now so with sharp tuning if you haven't done that yet, proper launch technique along with a fairly good suspension, you SHOULD break into the 13's. A 1.90 60ft would be great but there are too many factors that can come into play in order to pull good 60ft times. Good luck!
Car: 91z
Engine: 5.7 TPI
Just returned from the track and got in two runs
First: 13.98 @ 98.42 with 1.96 60ft
Second: 13.99 @ 98.27 with 1.97 60ft
Very happ to get my 13 sec slip and my dad whom i raced twice also got his best time off 11.42. Overall a great night!!
By the way tire size are 245/50/16 nitto DR and they really didnt spin a bit. AWESOME tire i will prolly never have anything but them on this car again!!!
