Ignition Problems Help ASAP!!!
Old Sep 27, 2004 | 11:42 AM
Hoss50's Avatar
Car: 1985 K5 Blazer
Engine: 350 crate w/TPI MAF
Transmission: 700R4/NP208
I am having ignition problems with my TPI setup. I need help ASAP, I need to get this truck on the road today if possible.
I pulled my distributor to replace my pickup coil and my reluctor ring (had a small crack). I marked everything when I pulled it out. It still didn't seem to want to drop in in the same place. So I manuallly found TDC and set the distributor. (I found TDC on the balancer and with a spark plug gauge)
I start the truck and timed it to 8* BTDC. The motor runs fine as long as the timing circuit is disconnected (like when you time the motor) When I turn the truck off and reconnect the circuit and start the truck it runs horribly and then dies. I can't figure out WTF is going on.
I replaced my module, ECM, and EST but none of it helped any. I am not 100% sure my spare EST is good but I know that the module and ECM are good.
I went looking for loose wires and things but I am at a lose. I can't figure out anything to get this thing to run right.
Why would the motor idle fine with the computer timing disconnected and not with it connected. It ran perfectly before.
I am getting no codes from the ECM. Only 42 when I disconnect the timing circuit, but that is normal correct.
Harley
P.S. The setup is a 88 MAF TPI on a stockish 350. Painless harness.
Old Sep 27, 2004 | 01:16 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Double check your wires and polarity and such. Make sure everything is pluged in and not playing you a mean joke. Loose grounds can do similar stuff.
Old Sep 27, 2004 | 01:17 PM
DURTYBIRD's Avatar
Car: '99 HO Z28 / '03 Trailblazer
Re: Ignition Problems Help ASAP!!!
Are you able to have it dle long enough to see whether the timing it advancing or retarding?
I noticed you said painless harness...this is a swap from another vehicle? Has it ever run right since this was all installed?
Old Sep 27, 2004 | 06:17 PM
Hoss50's Avatar
Car: 1985 K5 Blazer
The TPI is in an '85 K5 Blazer. It was swapped in about 10 months ago and was running fine till I decided to replace the pickup coil. It has ran great for awhile, I have just had problems with modules going out so I was putting in a new pickup to see if that might be a cause.
I can really tell if the timing is retarding or advancing.
Is it possible that the pickup coil is sending the wrong signal to the module?
It is a brand new AC Delco pickup coil.
Old Sep 28, 2004 | 05:54 PM
madmax57's Avatar
welcome to my world...i'm having similar problems with my 57 chevy w/tpi..also a painless harness..mine did same thing i have replaced same stuff including the esc mod..no luck..mine only runs bad after it warms up..its not a ground problem....the other day i was running it and i tapped on the computer box while it was warmed up and running. and it started its thing..even when i disconnected the timing wire...it didnt do that before..i'm going to replace my computer..i think thats the problem..there is little else left..on mine when it runs bad the light flashes ...no code tho?..let me know if you find the prob..before i do
max
Old Sep 29, 2004 | 11:38 AM
Hoss50's Avatar
Car: 1985 K5 Blazer
Anybody else have any insight? I really need to get this thing running good. I have hunting season in only 2 weeks. Thanks
Harley
Old Sep 29, 2004 | 10:56 PM
DRENNON's Avatar
Same problem here.Accel computer tpi 350
Was running fine with non computer dist. Changed to a computer controled dist .Ran fine.Set timming ,everything OK .Connected bypass wireand engine died.Could not keep it running.Changed
modual in dist.It ran long enought to check timming.
Timming was all over the place.20 degrees advanceand 20 degrees retard.Never did fine the problem.Switched back to non computer dist .works fine again
Old Sep 30, 2004 | 06:29 AM
madmax57's Avatar
i found that if i tap on ecm while running it runs bad all the time even with timing wire disconnected..where before it only ran bad warmed up...i'm looking for a 165 ecm anyone?..if that doesnt do it ..i will go to a regular hei...
max
9192camaro
16
Feb 3, 2019 12:21 AM
Infested
May 22, 2018 11:56 PM
mddaniel
Sep 8, 2015 05:16 PM
Bryan F
Aug 27, 2015 07:28 AM
Bryan F
Aug 18, 2015 02:28 PM
