Edelbrock TPI intake
Old Oct 2, 2004 | 02:55 PM
Edmond's Avatar
Car: 88' Corvette, 94' Camry XLE, 83' Z28
Anyone here run one of those? I was unaware that they made a TPI intake until recently.
I thought my only choices were the TPIS Big Mouth or porting my stock intake.
Any thoughts or comments?
Old Oct 2, 2004 | 04:06 PM
1992rs/ss's Avatar
Car: 92 RS, 05 GTO (sold), 10 TL AWD
Engine: 383 HSR w/DSC1
Axle/Gears: Strange S60/3.73
don't forget the accel manifold as well. in reality they all flow about the same because they are basically copy cat manifolds of each other. which ever one you can find for the cheapest is what I would go with. I just came across mine on ebay so went with it.
Old Oct 2, 2004 | 10:34 PM
Edmond's Avatar
How much is that Accel unit? The Edelbrock runs for about $370 or so.
The TPIS is $425.00 and they want to charge $75.00 to port it.
Old Oct 3, 2004 | 12:07 AM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
It's my understanding that Edelbrock makes all three. So which ever one you can get the cheapest.
Old Oct 3, 2004 | 12:12 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
I have the Big Mouth. Was ok for the 350, maybe needed a bit more with the TFS TW heads, but I personally liked it as I had set up the car as a sleeper. AS&M LTR's with the Big mouth was nice. I probably will swap out to an LT-1 intake next year with the 383. :shrug:
Old Oct 3, 2004 | 09:04 AM
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
all depends on whats done to the motor. if its a 305, the stock TPI will flow enough. If its a stock L98, you will benefit from bigger runers and some porting of the stock setup. If it's a modded L98 you'll want to port an aftermarket setup. I'm partial to the LPE Super Ram. You get the top end power without sacrificing any down low. If you're on a budget, try ebay for an Accel or TPIS base, SLP runners, and port the stock plenum.
1992rs/ss
Jan 31, 2025 05:10 PM
beastin91rs
Oct 9, 2015 07:38 AM
theurge
Aug 21, 2015 12:46 PM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
