idle timing with the est connected
Old Oct 3, 2004 | 01:14 AM
nsimmons's Avatar
Out of curiosity, how many degrees does a typical tpi ecm add to the base timing?
Old Oct 3, 2004 | 01:16 AM
Morley's Avatar
That depends on too many variables to give a solid answer.
Old Oct 3, 2004 | 01:43 AM
nsimmons's Avatar
Old Oct 3, 2004 | 01:44 AM
nsimmons's Avatar
lets try a stock 1991 l98 map system.
Im just looking for a ball park, any tpi system would be fine.
Old Oct 3, 2004 | 03:12 AM
Morley's Avatar
The variables I meant were things like temprature, idle RPM, MAP value, spark correction factor and possible knock retard.
But to find your specific "commanded" advance, just look at a bin file for your application, in the timing tables. That should tell you what it is "supposed" to running for advance.
Looks to be 20.04* BUT there are other things that can and will affect this.
Old Oct 3, 2004 | 03:31 AM
Morley's Avatar
double post.
Old Oct 3, 2004 | 03:52 AM
nsimmons's Avatar
20*? close enough, im not running a tpi im carbed, but i was just curious
eightsixseven
Dec 16, 2024 01:50 PM
specialized
Jun 18, 2022 09:26 AM
zeitghaist
Aug 18, 2015 07:33 AM
