need help, camaro spitting oil
Old Oct 3, 2004 | 06:39 PM
jayk2k3's Avatar
Car: 85 camaro z28
Transmission: auto to manaul
need help!!! camaro was leaking oil throw the valve cover, i thought. replace valve cover gasket, now its spitting oil all over the passender side of the motor. anyway to tell if its the headgasket, valve gasket again or sumthing else. Newbie
Old Oct 4, 2004 | 02:14 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
without a picture or a better description it is impossible to tell.
Old Oct 4, 2004 | 03:18 PM
cc 82Z-28's Avatar
Car: 82 Z-28
Engine: Built 406ci
Transmission: 700R4 w/3000 stall
Axle/Gears: 3.73 Torsen Posi, Moser Axles
Make sure your PCV is operational, not plugged up. That will cause it to push oil. It should rattle freely when you pull it out to check it. Give it a good cleaning or replacement if really gummed up.
Derick15
Sep 17, 2016 05:28 PM
toronto formula
Nov 10, 2015 06:17 AM
Navy8125
Aug 21, 2015 09:32 AM
92camaroJoe
Aug 13, 2015 06:07 AM
