TPI fuel rail lines in & out
Old Oct 5, 2004 | 05:37 PM
Oshdog's Avatar
Car: All GM
Engine: All Chevy
Transmission: TH350 / 700R4 / 4L60E
Axle/Gears: custom GM 8-1/2" 456 posie
Can anyone please tell me which line is the supply and which is the return on the TPI fuel rail? Is it 3/8 supply and 5/16 return or is it 5/16 supply and 3/8 return?
Old Oct 5, 2004 | 05:47 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
3/8" supply, 5/16" return
Old Oct 5, 2004 | 08:05 PM
Oshdog's Avatar
Car: All GM
Engine: All Chevy
Thanks,
Thanks for the info
I am using an aftermarket MSD 110 PSI fuel pump. Would you know if the stock TPI fuel regulator is capable of handling this much pressure?
The MSD pump has a 3/8 inlet and a 5/16 outlet. I will have to make up some kind of fitting to boost the 5/16 outlet back up to 3/8. I’m not sure why they made the outlet of that pump 5/16, that is why I was confused about which inlet line to use on the fuel rail.
Andrew6.688
Dec 13, 2015 10:59 AM
Sanjay
Aug 12, 2015 03:41 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
Kaweh
Aug 9, 2015 02:54 PM
92projectcamaro
Aug 6, 2015 01:20 PM
